Jimmy Brooks
Hello all!
My LR4 has developed a suspension noise from the front right wheel that has gotten progressively worse over the past 5 months. The noise happens over rough surfaces. As of now I don’t have the abilities to lift the car above ground but I am working on getting them to investigate it. I would much rather wait till the summer when I am home to replace whatever it is but I can improvise if I have to act now. But I wanted to share this video and see if anyone has heard a suspension noise like this so I can start estimating my costs to replace it.
For context my truck has 158,300 miles and the whole front suspension has been replaced. Here is a list of everything and the mileage.
Front struts: 100k
LCA: 100k
UCA: 135k
Wheel bearing: 146k
Sway bar links: 146k
Sway bar bushings: 156k
The only thing that hasn’t been done is the tie rods. The wheel does not shake while driving. The ride is not impaired, the shock absorbers are not leaking and the air springs are not either.
Here is a video of the noise.
I suspect lower control arms but let me know what you guys think.
Front struts: 100k
LCA: 100k
UCA: 135k
Wheel bearing: 146k
