Transmission Oil Cooler Pipe.
deeb
hey all.
98 disco I
107K
auto
the pipe that runs from the radiator down into the transmission oil cooler is '*******' out a fine stream of oil.
anyone have any good ideas of how to patch the hole?
anyone have one for sale?
really dont feel like buying a new one from roverparts...:hmpf:
thanks
chad
Find a local Hydraulic shop and remove the pipe... have them make a new one... best to do both while you are there.
wolf
hey all.
98 disco I
107K
auto
thanks
chad
In the interim there is a special tape that you can get at your local autoparts shop - i.e., its Magic Tape or Miracle Tape (don't know what it is called down there) and you can wrap it around leaking coolant and oil lines and, yes, it does work! This stuff should be in your onboard repair kit at all times. It adheres to itself when you stretch it and bind it around a hose - and you can do this with significant pressure. Wait until pipes or hose are cool - clean area with good cleaner and bind - voila! I have use it out in the bush at high altitude when I sprung a rad-hose leak (had to wait for things to cool down before I could use it though).
Wolf
