Where does this line connect?
jsob1970
2012 LR4. I just replaced front and rear coolant tubes. Was reassembling everything but can not figure out where this line connects.
I’m sure it’s a silly question but can anyone point me in the right direction?
Thank you in advance.
jlglr4
Northern California
Loos like the breather for the front differential (in which case it doesn’t connect to anything else). I have the scv6, which has the breather in a slightly different position, so not 100% sure, but that’s what it looks like to me.
Jimmy Brooks
Pasadena California
that coolant hose is supposed to go to the throttle body. the fitting is located directly under the throttle body, when i did a valve decarb I found the easiest way to connect that is to unbolt the throttle body from the manifold, connect it, then bolt it back up to the intake manifold.
richord
NJ
I just replaced my radiator and all the hoses and noticed this as well. Mine has a cap over it, so it wasn't connected the anything.
