Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Loos like the breather for the front differential (in which case it doesn’t connect to anything else). I have the scv6, which has the breather in a slightly different position, so not 100% sure, but that’s what it looks like to me.
that coolant hose is supposed to go to the throttle body. the fitting is located directly under the throttle body, when i did a valve decarb I found the easiest way to connect that is to unbolt the throttle body from the manifold, connect it, then bolt it back up to the intake manifold.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
