06 Range Rover random misfire comes and goes away
Albert gaitan
San Bernardino ca
How’s it going guys I’m new to the range rover world I recently got a 2006 Range Rover supercharged with the 4.2 engine I’ve noticed the truck gets random misfires and the check engine light comes on and is giving me a random four cylinder misfiring and it’s very random I’ll delete the code and the truck will run good And once I turn off the truck and turn it back on check engine light will be back on sometimes even while driving she’ll be miss firing Out of nowhere and it won’t go away and after a bit sometimes it goes away when I delete the code or sometimes it stay very weird I’ve done spark plug change oil change clean mass airflow sensor clean pcv valve. Pretty much everything that could possibly be Sometimes I’ll drive the truck for a long time and all I do is delete the codes and she would run fine and sometimes at a nowhere I start the truck she acts up the whole time even when I delete codes and say engine Performance reduce Thank you in advance
georgekale
Try switching the COP (Coil Over Plug) with good cylinder. If code still there,than you can eliminate the coil. Try doing that with the spark plug. Should eliminate two items.
