cold engine rough idle
Hock
very rough idle when engine is cold, back to normal when it warms up. dealership tried cleaning fuel injectors, new plugs, etc. fixed it for one day, then it is back to the same issue. two land rover shops are perplexed. LR NA did not return my email. LR3 2006 HSE. Hmmm.
GeoRover
Can you access a diagnostic tool from a local auto store and see if you get any error codes? Sounds like ignition coil misfire? Maybe it's about to die or something. Easy to replace if you are a DIYer.
STQAddie91
