tjp74
- Joined
- Jan 29, 2010
- Posts
- 147
- Reaction score
- 0
Looks like my worst case senario or fear turned out to be true.
Ok, so call me stupid to get into this mess but it's too late and I moved on.
Now, I need to figure out the best wa to get out of this mess with minimal loss.
Long story short, I bought this DII last month. Previous owner was expriencing overheating issue so he got the headgasket replaced only to find out the problem is still there. Shop thought it was a radiator but I thought may be a themostat. I bought it knowing that there is a chance that I may need a new engine. Luckly I didn't pay it too much.
It turns out that I have a very small combustion gas leak into the cooling system. It's very small so I don't see much bubbling at the idle and engine would idle all day long with cap off witout overheating. The problem is, with cap on and if I drive it hard, excessive pressure builds up in the system and I believe when a big air bubble gets created around the water pump, coolant stops circulating and engine overheats causing even bigger air bubble. Plus high pressure will slowly push coolant out to the over flow tube causing the cooling system to dry up in few days causing overheat too.
I don't believe I have a dropped sleeve as it idles and runs perfectly fine, no oil in the coolant or coolant in the oil. As long as I keep relieving pressures by opening up the bleed cap letting air out every stop, it feels like truck would run forever.
It believe it's a tiny crack behind the sleeve. I found it on internet that it's possible to have cracks without sliped liner on rover V8.
Am I correct on my finding or am I missing something?
Anyway, I am looking at several option.
1. Get rid of it as is.
2. Fix it up.
2a. put a used engine
2b. Seize the opportunity and upgraded to 4.6L used engine.
3b. Since heads were all checked out fine, and engine only has 65K miles, take it apart and resleeve the block and fix the crack.
Or???
Also, how hard is it to pull an engine from DII? Hour wise?
What's the good way to resleeve the block? I heard "coscast" block or top hat liners. Good place to buy the parts in US?
2. Fix it up.
Or???
