Got bad news, tell me it's not so!
bcaese
Its probably easier to start from the interior inside, poke through, then pull it from the engine bay. Depends on your connectors. I always put the connector on last, and feed the wires through from the interior.
That does sound a lot easier:smile:
Can you see the grommet clearly from the interior when you remove the panel under the steering wheel?
  • So remove panel under the steering wheel
  • Poke small hole from the interior out
  • Then run wires from interior out
    • Then run wires through to the center console, where the switch will be
Please let me know if I am missiing anything else:smile:
lilredpo
For what its worth, the factory nav system just isn't that great. A $300 Garmin will serve you better.
+1, we almost never use the onboard GPS, always plug in the Garmin.
Lately, I find myself turning off the screen at night so it isn't so bright.
They also want $200+ to load the latest maps.
