Is an LR4 Body Lift Possible?
HarryO
Not sure if these are what you’re after but there are a few option LLAMS Kit, Johnson Rods. I have the LLAMS and have these settings.
avslash
The Lone Star State
Anything is possible if enough money is thrown at it.
There were pictures of, I believe, a Range Rover Sport out of Nevada that had one done and was running something like 37" tires. Can't recall if it was on here or on ExpoPortal.
I like the idea. Raise the body and run whatever tire, and keep air suspension at normal height so you maximize articulation.
mm3846
LI, NY
Subframe lift. Never seen one for the Disco3/4 and RRS, but the new Defender and L405s FFRR and RRS have them available
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
I know what you're talking about. I followed his build for a bit. He started off with 35s and then 37s. This is what he did... https://jaustonfab.com/range-rover-lift-kits/
txfromwi
If you are only looking for 1.25", are you aware that with the IIDTool your can reprogram your (air) suspension to default to any height within the total range of motion of the system.
I.E. you could simply reprogram the system to call default height at 1.25" higher.
