Local Tire store refuses to install S rated tire on 2015 LR4
ar077
Las Vegas, NV
Completely agree regarding tire age. When buying a set of tires I always check the DOT code to make sure they were all manufactured at--or close to--the same time and are not more than 2 years (preferably <1 year) old. And even if the spare hasn't touched the road I replace it every second tire change.
Quijote
Metro Boston
I'd agree with tire age. Note that age is not as critical when the car is out of the sunlight. Nothing degrades rubber and plastic more than UV. Leaving a car out 100% of the time in a sunny place could make the tires degrade in just a few years. This is why there was a recommendation on not having tires older than 6 years.
BeemerNut
Costco operate like that, they allow one deviation from what was original installed. A problem when Ys were installed as OEM. They eventually mounted my H rated Michelins but the wheels had to be loose from the vehicle. They would not mount the tire to the vehicle.
Perfect, cash and carry walk in dismounts, mount and balance. A little bit of extra trouble and time with another vehicle to transport wheels and new tyres. Savings alone purchasing tyres from someone else more than having another vehicle transporting.......Try dealing with changing tyres on split rims.....~~=o&o>.......
magus
Denver
Makes sense to me that places like Discount would only support factory equivalent or better load ranges: "The load index explicitly indicates how much weight a tire can carry."
00Jam
