Maintenance charger for battery
Frank8
Vermont
my local indie said he installs a lot of leads that go from the battery to a plug in the grill that is capped off. When in garage one can uncap it and plug in a maintenance charger.
Is this a worthwhile thing to do? It sounds as tho it might be a good 5hibg for a battery in cold climates.
Frank
Bethesda, Maryland, USA
I have an inexpensive maintenance charger for my son's car while he's at college. It came with a pigtail connector that can stay on the battery posts and quickly connect to the charger's main cord for a similar type of access. It's not very long, though, so it might require popping the hood each time you wanted to connect. I'm sure that longer cords can be fabricated or purchased.
I think it can only help your battery. These chargers are smart enough to plug and forget and will also condition your battery as needed.
How long do you go between driving your LR4? I've always thought of maintenance chargers as things for weekend cars and not so much daily drivers. With the Land Rover charging system, though, who knows; could be a good idea.
Frank8
Vermont
Good point. I use it frequently but for example it’s 1 1/2 miles to the P.O. most of my local driving is under 20 miles. I do the occasional 200-500 mile trip but that’s rare. Most of it is very local.
It’s an intriguing idea to have an accessible maintenance charge plug. Would it help the battery?
jwest
Seattle WA
If you never really run it for more than 10 minutes a day on short trips with 2 starts, then the maintainer might be good. Just be sure it's a proper smart maintainer, not a simple trickler that may drive too much in when topped off.
avslash
The Lone Star State
I have a Noco G7200 mounted under the hood, with a male 110V receptacle mounted in the front bumper.
Works great for camping where shore power is available and for keeping batteries topped up at home.
I would do it again.
