I was wondering if it's better to keep all 5 tires with similar amount of wear. If I didn't rotate the spare, the tread depth between the spare and the other 4 tires will continually grow larger. Say I was down to about 6/32" on tires and I got a flat and needed to use the spare. Would it be a problem to use one tire with full tread depth with 3 other tires that have considerably less depth?Little harder to keep track but it is sure a waste when not being used.
The local dealer (Waukasha, WI) stated that LR4 tires should be rotated side to side rather than front to back etc. Can anyone verify that this is correct?
