What Did You Do To Your LR Today?
BBLR3
St Petersburg, FL
Clever use of the spade connector, how did you get it on the existing cable?
The metal is pretty soft. Just spread both the round parts that normally grip the spade enough to fit over the cable. Used pliers to crimp onto the cable.
BBLR3
St Petersburg, FL
Just finished installation of new rear Aerosus air struts. 1.5 beers out of 6 for difficulty. Hardest thing is the top inside 15mm nut on the drivers side. Passengers was the same but had better access. Rusty threads made these a real PITA. I'd say if someone is planning to do these in the near future, start putting penetrating oil on them a week before you start. Maybe get a small metal brush to clean up the exposed threads a little before trying to take the nuts off.
M32H32IS
Texas
My weekend project
Land Rover Joe
Oxford
My weekend project
I think a much-needed "upgrade" (probably should have come stock...). Good luck to all and while I haven't needed mine yet...it is useful and if required, definitely worth the time/money/effort! I ordered mine direct from Italy although I understand Luck8 stocks them as well. Maybe someone has some stories about the Land Rover Passion Upper Tailgate kit for Discovery L319.
BBLR3
St Petersburg, FL
Mine failed on me around 80k miles. Had a shop fix it. Im at 167k now and the way things go sometimes like clockwork, I decided to be proactive. I also put a black ziptie around the factory cable end to help ensure it does not pop out from the plastic holder breaking. Hopefully all the work will be for nothing and I never have to use it :D
powershift
Nevada
I took an orbital buffer to the clear coat haze that I had growing on the paint in a couple spots as well as the entire truck using a light abrasive rubbing compound with no fillers. It took the haze off the bumper completely, all the spider webbing and wipe marks from washing were rubbed off. The fender haze came off too.
I'd like to pull up the plastic grate on top of the rear bumper and hit the top corners better because its hard to get the buffer up against the plastic with the 90 deg.. I'm afraid of breaking it or bending it lol. The whole truck shines like a diamond now with a filler, polish and UV protestant.
TVone
Fort Worth, TX
I did an oil change at 157K miles and I am trying the Valvoline Restore and Protect 5W-30W. Plan is to change the filter after 500 miles, then 1K, then 2K to see if there any change. I bought the car in April at 148K. I did the first oil change at 153K.
