Kaaae
- Joined
- Sep 28, 2012
- Posts
- 355
- Reaction score
- 5
I usually stay in low and shift on the fly as we get closer to camp. Some of the trails between the obstacles are not for high gear.
Second, I will coast shift the car into low when im on the trail. This is at low speeds (under 20).
1. remove foot from gas
2. shift into neutral
3. press low/high
4. shift back into drive
5. resume gas
Sounds exactly like where I go (Hollister Hills SVRA). Thank you for all this advice.I usually stay in low and shift on the fly as we get closer to camp. Some of the trails between the obstacles are not for high gear.
Thanks, RoverGuy7!HDC is fully functional in high range, not just low.
Works up to speeds of 19mph, and target speed is adjustable with the +/- switches on the wheel.
Awesome - thank you!Both high and low range HDC needs to be turned on, however some Terrain Response programs automatically engage it. It can always be engaged in low(depending on speed) but in high the transmission has to be in R, D or 1, manual selection of another gear in high range will not allow HDC to operate.
