Towing upgrades
Gusterson
Colorado Springs
Hello
I have a 2015 LR4. Looking for advice on towing a heavier travel trailer. Was towing 20’ TT around 4000 dry with no real issues in Colorado. (No WDH) Upgrading to 26’ at 5000 dry and 490 tongue weight dry. Looking at Curt hitch (600-6000) for upgraded tongue weight and AT tires for my 19” wheels… any additional suggestions? Small lift? No rhino ox hitches in stock
mm3846
LI, NY
You don't need anything different than factory equipment. XL rated tires and the factory hitch. If you don't want the factory hitch, I'd send a message to Safari Guard and see how long until there's are ready too ship.
jmars
Thought on the 2015 tongue weight was 770. I must be mistaken but I thought It was increased over the notes 550lb previously stated.
My hitch has 770 stamped on it, but I believe the car manual states a lower weight.
mm3846
LI, NY
the hitch max load is different than the tongue rating. not sure why it is that way, but it is.
Check out SafariGard. The guy made some improvements to the Rhino OX hitch and made a batch of them and very reasonably priced. I think it was going for $450.
Paul M
Phoenix
Hello
stock hitch will work fine w/o WDH; check out safarigard hitch on Facebook or iNstagram that is class IV that mounts higher than the "plow" Your well within the 7700 GVWR and 10% hitch weight
spodie
California
I installed the Rhino OX hitch receiver. It allows for bit more ground clearance. My only complaint is that it's not very deep. I had to take an inch or so off my hitch. https://www.snomasterusa.com/product/rhino-ox-hitch/
