Hi Folks, following my recent Timing Chain endeavor, I'm getting the following code which returns immediately after it's been cleared:
"P0232-24 (28) Fuel pump A - secondary circuit high - General signal failure - signal stays high"
But unlike others, the truck runs absolutely fine, I've not broken down like @MellonRover described here:
www.landroverworld.org
In the timing chain thread here:
@Rover Range had me check fuse F1 (25A) which was fine... I'm wondering if I'm running in to electrical issues, perhaps a failing battery? FWIW, I just measured the battery voltage at lunch time and it's very low at 11.8V but the temperature is also 24F (-5C). I have noticed while driving that the rev counter needle back light has been flickering but other than this the car seems completely normal. I see the voltage generally at about 14.7V when it's running. Any thoughts?
Thanks.
Sitting on the side of the road listening to a rodent chew my truck
2010 died on way to work. Plugged gap in and showed p0232-24 fuel pump A secondary circuit high. General signal failure signal stays high. So lost pump 2....while waiting on tow I can hear chewing.... Friggin mice!
Looking to purchase timing chain tools
Here's the cooling hose mentioned above; the dangling pipe is not yet connected but connects to the water pump: That hose is in the wrong place. Needs to be on the upper crossover pipe.
Thanks.
