HD package retrofit
Rover Range
Texas
The 48 pin connector is there. Since your vehicle didn't have the e-diff. the connector is blank.
The e-diff connector would plug right in.
I would need to have your VIN to verify exactly what you have.
Rover Range
Texas
Sorry. With the JLR cyber attack, I'm not able to access the wiring diagrams at this time.
I can use the year and model to access the schematics. Either way, the connector should be there.
Lr4KP
North Carolina
Is this the connector you’re referring to or are you saying there should be a separate connector for the differential. I can see where there is a spot for another connector on the plastic mounting surface beside the big connector pictured here
Lr4KP
North Carolina
I have the carrier and axles installed. Is there anyone that could verify the 48 pin connector is wired coming out of the interior into the connector?
Lr4KP
North Carolina
I was able to get the wires from the diff and temp sensor pinned into the 48 pin connector. Using the gap tool I was able to turn on the diff and update the ccf. I now how a working fully functional retrofit locking rear diff
