Disco loosing power when flooring the gas
245 sleeper
I had the shop scan and the following codes:
P0171,P0172,P0174,P0175
p0441
P0734
P0733
They said the last two are transmission code. I appreciate if anyone can elaborate those codes for me.
245 sleeper
update on my Disco II, I replace the MAF sensor and all the symptoms are gone and the disco run like a champ so far. will see if it creeps back up.
sorry have been in and out of town for work. With the codes you mentioned I was going to say MAF sensor...
Disco Mike
Would you please go get your codes read and make an attempt to get this fixed. Why sit here and guess what may be wrong without even checking for codes??????????????
Disco Mike, he did have codes read, see a couple posts above.
Kylis
I had similar symptoms recently, turned out to be the crank sensor.
245 sleeper
Kylis,do you have a D1? Disco Mike, I did what you have ask me and inspight of that it sounds as you have no intention to give me any advice after all, anyway it's all fixed and I hope this will help other forum members with the same issue.
Slytrellis
