Looking for a decently priced 2011 LR4 engine 5.0 non supercharged
Stookey
Lexington, KY
So this is probably a long shot but I can’t not try. I just picked this rover up and the motor is seized. Looks like oil starvation ar this point but I still need to pull the heads. Knowing my luck I’m going to need a engine. So anybody have one laying around?
First post, hopfully posted in the right place
Thanks,
Justin
What is your definition of decent? A used but functioning V8 is going to cost $5000-$10000 depending on miles.
Tapps33
Bath, Maine
It depends how long you can wait. I’m actually in the process of swapping my NA for the SC version. My NA runs fine, but it’s a high mileage engine at 170K miles. Really all it needs is the timing gear swapped….VERY easy with the engine out. But I decided to swap the whole engine instead….cause I like a challenging project!
That said, we’re moving from Maine down to Memphis at the end of the month and the Sc engine is still at the machine shop so I won’t actually make the swap till late July, August sometime after I arrive in Memphis and get a little settled. The LR4 is one of our DD’s until I start the swap. FYI, mine is a 2010 model.
If you can wait for it, I’ll sell you mine the second I get it out for $3K.
TrinidadLR4
NE Washington DC
my used engine(same year, 40k fewer miles) was 6900 shipped from a dismantler on Ebay. Also consider sourcing a 5.0 engine out of a Jaguar XF, as they're apparently the same/very similar and somewhat cheaper.
Tapps33
Bath, Maine
I sourced my SC engine from a jag, the only real differences I’ve found are the oil pan, oil pick up tube and oil pump manifold are different. I think I spent roughly $400 sourcing used LR parts to convert the jag engine.
I have heard, but can not confirm that the accessories are a little more robust on the LR engines as they’re supposed to be able to go through water….but I can’t prove or disprove that theory.
Stookey
Lexington, KY
Decent being not seized but still in need of head gaskets or something of that nature. I believe my top end is good so if I can find one with a good bottom end maybe I can make one good motor out of 2 bads if possible
Stookey
Lexington, KY
Man that’s a good price! To be honest I’m not sure if I could wait that long but only time will tell. I will keep you informed and thank you much for the offer. Good luck with your move!
f1racer328
AZ
I read the alternator is waterproof in a brochure, or some Land Rover document. I tried finding that same document a while back, and couldn't.
Not sure about anything else though.
Tapps33
Bath, Maine
No worries! If you can’t wait and find a one sooner, go for it!! It’s just an option, that’s all! I don’t even have my SC engine back from the machinist yet!
Greggnvt
Northern Vermont
I could be wrong, but I don't believe any 5.0 LR4's sold in the US came OE with a Supercharger... (title of your message)
