@Jimmy Brooks - I have the exact same config and used your settings - thanks. Curious, what do you run your tire pressure at? Assuming it is not the LR4 standards, also wondering if they can be changed in the TPMS.
Here they are. My tire size is 265/65/18 so if your tire size is different this most likely won’t be accurate with your real speed.
So no change to Tire Rolling Circumference?Awh nope - size, width, rim size, and MSB - that 30 is an odd one that down is up and up is down. So when I changed mine this show prior to the commit.View attachment 13139
