Speedometer recalibration with IID Tool
BriComp
Arizona
@Jimmy Brooks - I have the exact same config and used your settings - thanks. Curious, what do you run your tire pressure at? Assuming it is not the LR4 standards, also wondering if they can be changed in the TPMS.
greiswig
Oregon
Here they are. My tire size is 265/65/18 so if your tire size is different this most likely won’t be accurate with your real speed.
Reviving this...
Is the "Tyre size - MSB" parameter the ONLY one I should be changing?
Also, you had changed it to 30, but from what? I feel like I'm reading conflicting messages as to whether that number should go up or down as the tire diameter goes up.
BriComp
Arizona
Awh nope - size, width, rim size, and MSB - that 30 is an odd one that down is up and up is down. So when I changed mine this show prior to the commit.
BriComp
Arizona
Nope - did not touch / change. Just the parameters above. Interestingly many things changed once those settings were updated. Speedometer is dead on but the rolling circumference may impact something other than that.
CRYA
Napa Valley
I just changed the original specs. Will check out and confirm with gps tomorrow. Thanks for the specs and images!
BriComp
Arizona
Interestingly that rolling circumference can only go up 20 so not sure it is what it is. I plan to reach out to support and see if they know...if I can remember to do so. In the mean time I changed mine to 2385 to see what if anything it impacts.
Sent from my Pixel 4 XL using Tapatalk
BriComp
Arizona
And GAP tech support said "The value does not reflect a direct measurement.
Menu--Car Config--Instrument Pack--Tyre Size MSB - IPC
Is the correct setting, others don't work"
CRYA
Napa Valley
Yeah I received same somewhat fuzzy response. Anyways, your settings have my Waze speed and digital speed dead on. :driver:
Vintage99
