Fitting Oversized Spare Tire Underneath
bushway9172
Does anyone know if I could fit my 265/65R18 spare tire and rim (18") underneath the truck in place of the stock spare (non-HD package in case that matters)? It's about 31.5" inches in diameter. Any input would be greatly appreciated before I give it a try.
Remove the heat shield between spare and exhaust, deflate the spare tire down to about 10 psi, then crank it up so that the "front end" (facing the front of the car) goes up in the well first, and the rear follows. Even though the BFG sidewall is likely to be very stiff even when almost fully deflated, you should be able to slide it up there - with pretty much zero room to spare - in those conditions. My 285/60R18 Cooper Zeon LTZ spare of nearly identical diameter used to fit on my Sport that way.
Needless to say, you will need to carry an air supply / compressor with you at all times.
PS: Since it will be a real tight fit, you may want to test and make sure that the tire will release after it's cranked up there for a couple of days. You don't want to find out the wheel is jammed in the well on the day you really need that spare, in the boonies with no cell phone signal...
bushway9172
Thanks a lot for the help! I'll give this a shot within the next week or so. Is there anything special I need to know about removing the heat shield or it's pretty self explanatory?
bushway9172
Better late than never, right? Also I know a few people are interested in this topic right now...
Anyway, I just got my 265/65R18 BF Goodrich All-Terrain fitted up underneath the truck. I removed the heat shield, and cranked it up with deflating it. I'll check it in a few days to make sure it releases easily enough. If it's a pain to release, I'll deflate it some.
It is obviously heavier than the factory donut... does anyone know if I should be concerned about the added weight/stress on the cable that holds it up?
Some pics..
I wouldn't worry about the extra weight putting too much stress on the winch, it's a pretty chunky steel cable after all. Are you sure it went up all the way? Maybe it's just the perspective, but in the first photo it looks like the wheel's hanging a bit too low, especially the front end (it looks lower than the exhaust from here.) The rear looks about right. You should be able to slide a hand over the tire and feel whether the upper sidewall is contacting the four bumpers in the well or if there is clearance between them. If it's up correctly, it should be flush against all four bumpers.
bushway9172
Thanks umberto I'll take another look at it. I was pretty certain it was all the way up. Will check shortly.
Kaaae
I'm doing this today. That's for the peer pressure Brandon! ;)
Kaaae
So not sure if it is fitting correctly but holy hell is it tight!
I did deflate to 10psi.
