RR supercharge 2006,wiht out AUX !!!!!!
binbuty
Hi everybody, I have range rover supercharge 2006,Looking to use my IPOD,But im taired to find a solutions,First thing im try to use interface audio\vedio to connect with NAV system,And i find there r no audio input in the system :frown:.
http://www.navvideo.com/navvideo-models-nv_gvif_lr.asp
also i read about www.xtremerovers.com ,It fix only for U.K spece,And audio system difrent betwen main( as they showing in youtube):
YouTube - Range Rover iPod iPhone
http://www.xtremerovers.com/range-rover-ipod-iphone-audio-connection-p-1.html
Sooooo ,Any one can help me please.>>>>>
I am not an audiophile per say... but can't you just tape into the audio output from say the CD player and put it on a switch, so when you use the IPOD you get sound from it, then if you want CD just flip the switch again...?
binbuty
Easy to say that, but it is difficult to apply...thank's Joey.
GreyMatter
i got frustrated with the factory option choices for the ipod so i just started using my fm modulator one
binbuty
F.M transmeter will work fine,But some time u cannot hear anything in tunnels or coverd areas.....
GreyMatter
its the same unit i used in my last car...it has never lost signal...the serius sattelite loses signal from driving under overpasses so i can deal with it :)
DrewT55
I use the aux line in the rear of the center consol and then have an in line amp called a Boostaroo, which boosts the volume to match up to the FM and CD volume. It also give a boost to the high and low frequencies.
darthRover
Where'd you get Boostaroo?
I just got an 06 RR and I figured out to use the AUX in the rear panel but the volume is a bit low. thanks!
PE_in_UAE
