cannot find my stupid photos
Thanks. I will surly look into this. I just don’t like the idea of bringing the Callipers.
Is it the offset from 53 to 44 that makes the comps fit?
I’m trying figure out what makes the Comps so much different than every other 18 inch wheel out their.
I have an appointment on Saturday at a wheel shop to try on 3 types of 18 inches that are marked up as able to fit on LR4’sI honestly don't know.
I have read, anecdotally, that they are machined with less taper and a different offset than the factory wheels.
I can say, that all I Idid after I receiveed mine was to remove my spacers and install the wheels and they worked perfectly, although my truck did have the mods I listed above.
I suspect you would still need to heat gun the forward lower inside edge of the driver's wheel liner. There is a bulge there from the factory, and was a place I had to do some reshaping when I first went to 18's.
This thread ******* delivers.
It's always entertaining to see jwest educate you fools about serious off roading -- don't you dipshits know he's changed his own suspension bushings and put ******** BFG tires on for those monster off road adventures you only dream about? You'll need a tap, perhaps know how to cut some plate to be as awesome as he. If you don't have a tent on your roof already I don't even know why you're in this conversation.
You're welcome to ride ***** in my rock crawler any day, jwest - I promise you'll have fun going up some **** you would have never considered trying, and I hope you'll be condescending about what I should have done :beerchug:
You're in Georgia? Where? I'm in NC right now. Do I need to meet you in North Georgia with my lr3 rolling it's winter MS2's ? What's your crawler?@jwest
Would you be willing to post some pics, or give some details on how you did this?
i have been thinking about trying to configure something similar.
I have a ProSpeed rack, but essentially all I use it for at this point is a platform to put some lawn chairs on to watch my girls lacrosse games, or similar. Otherwise, it is largely useless and dead weight and extra height at this point.
Would really like to hear any details on what waffle boards, or bridging planks you found, and if they will support the weight of your truck if you actually need to use them for bridging or getting a tire up on a rock ledge or similar.
I have a couple of mats that I take on trips to difficult trails, but they are absolute beasts. They weigh over a hundred pounds combined, and would literally support a semi truck. They were made for decking on off-shore oil rigs, but found their way to me for about $15.00 many years ago.
If I could find an appropriate waffle board, or bridging ladder, my thought would be to take two or three of them, and just span them across the factory short roof rails and then secure them with a square nut inside the channel on the roof rails.
Highly unlikely any of those are load rated to the heavy lr4. Usually 'cheap' becomes expensive at some point in time. You are trying to save, what, maybe a few hundred $? Unless it's the 18's you can find on this and other LR enthusiast sites, they will not fit and/or are not engineered for anything besides mall crawling.
Any wheel I have seen other than what is truly made specifically for the Land Rover has ridiculous lips, fake bead lock bolts, chrome edges, general bling and are literally garbage.
You want a badass wheel, look at Mudtech or get the Compomotives $220 usd or the Aussie steelies for $1025 usd: https://www.tuffantusa.com/
sarcastic POS LOL![]()
