maintenance history since new 2013
powershift
Nevada
I feel your pain, every time I feel like I got the car fully sorted another item comes up. I had planned on doing valve covers, upper and upper timing covers when all the sudden my alternator dies, I replace that and then notice while I’m down there that there’s a coolant leak coming from my radiator. Get the radiator sorted with my AC system which hasn’t worked right for years (prior shop used cheap parts, works great after ANOTHER condenser and compressor) oh the review I left on that shop… anyway, then today I notice that my tire ware on the rear is a little odd, everything on the rear is original and I’m at 147k now, sure enough it needs rear upper control arms. I’ll do them myself to save money. Still need to do those valve covers and timing covers, just putting it off because I have to pull the injectors. Still also need to change both diff fluids and the t-case fluid. I’ll be doing all of that myself as well, and hopefully then I’ll be able to hold my head above water for a little time.
Sorry to hear that. Don't give up. What was the mileage when t he alternator failed?
M32H32IS
Texas
Damn, I took old Boom Boom in for an oil change at 123,157 miles on the clock and 5,008 miles since his last oil change. Had an appointment for Thursday. On Wednesday I thought, "So nice to just take him in for an oil change and not a repair." Then, of course, I get a suspension fault. Compressor and valve block are going bad. Time to replace. At least I had a nearly-new Arnott compressor and valve block and plastic housing on hand that I picked up from a wrecked 2013 LR4 back in November for $361 for just such an occasion. Still, I'd like to just make it to 2 oil changes in a row without something breaking.
2013 Land Rover LR4 HSE LUX HD Package
123,157 miles
purchased used 8/11/2020 with 69,200 miles
My tally so far is:
$9,841.80 routine maintenance
$17,228.83 repairs
$27,070.63 total
$0.502 per mile for repair & maintenance
*this does not include what I call "extra stuff" like roof rack, bumpers, winch, skid plates, lights, etc.
Dang. I thought my $19,000 and change was high (that includes Renan engine) you clearly win!
ttforcefed
latest $60 total
DateMilesWorkPrice
4/1/20146,000oil200
9/30/201417,756oil, annual10
3/2/201523,345oil, pads/rotors all 41,225
9/19/201530,928oil211
8/8/201646,425oil195
4/13/201758,270radiator1,263
5/22/201760,473oil, 60k mile service, tranny, stf1,905
2/22/201871,836window switch548
4/26/201875,008oil, cig lighter fuse258
7/24/201879,062oil, 4 rotors/pads, differential, upper lower radiatior, water pipe etc3,800
12/4/201885,534right front heights sensor and strut2,067
1/2/201986,684oil, spark plugs, parking light968
1/7/201987,432control arm and shock1,535
6/17/201994,080Oil, EBC front and rear pads500
9/14/201997,500trunk actuator300
10/2/201998,580Running boards1,200
12/12/2019102,045oil change200
1/4/2020102,650right front sensor180
7/8/2020107,195oil150
11/16/2020111,892battery333
12/15/2020112,608oil, cabin filter737
6/15/2021117,960oil, front and rear pads, alignment, tires2,200
8/20/2021121,000front and rear bumpers painted3,500
10/14/2021123,387oil, differential fluid, lower cntrl arm and joints, alignment2,284
2/24/2022126,035oil, timing chain, water pump, coolant system, belts, plugs7,593
6/12/2022132,473oil, AC service569
10/31/2022137,844oil, coolant, alignment800
11/29/2022140,508universal joint steering, tranny service1,291
3/3/2023145,008oil162
7/7/2023151,662oil162
8/11/2023152,000y pipe, alternator, battery, new pad sensors, front and rear brakes4,958
8/14/2023153,138fuel flange recall, fuel leak460
9/27/2023155,245oil162
12/1/2023156,600replace power steering pump, replace rear calipers/hoses, 4 wheel alignment, oil change2,812
2/10/2024161,675oil850
2/23/2024161,706oil, replace vacuum pump with seal, crankcase breather diaphragms, cleaned intake and throttle body, new plugs2,206
4/17/2024163,726ABS wheel speed sensor459
6/1/2024165,149oil,replace oil cooler, sunroof drain, rear wiper, replaced MAF, replace cig light, replace start stop button.2,562
6/2/2024166,000CarPLay1,150
9/13/2024170,210oil, check egr809
11/18/2024175,100oil, new tires, replace coolant tank, replace lower control arms, cabin filter, radiatior, heater hose, intake vacuum solenoid7,883
60,657
itsaguything
Manotick, On, Canada
Thank you for keeping the tally.
I’m on the fence if oil, filters, brakes, tires, and other common maintenance items belong here. If they do, wouldn’t fuel belong here too.
What I find most useful is catching those repairs that I was not expecting to see. And identifying the mileage of the occurance.
Thanks again.
ttforcefed
Just a couple years old and OEM
ftillier
Portland, OR, USA
Was it pinched during install or junk from the factory? Are you replacing just the oring or the whole crossover?
PE_in_UAE
